Error: "Failed to get configuration from KeyShot Hub"
Customer will receive this error when trying to connect to the Hub - "Failed to get configuration from KeyShot Hub"
Issue
Users receive the following error when trying to connect to the Hub:
Environment Details
  • KeyShot | KeryShot Hub
    • Any versions
Cause
  •  HTTP (80) Port needs to be opened through the Firewall. If not, this error will occur
Workaround
Open port HTTP (80) via Firewall. Developers are working to change the port to an HTTPS port.
