FlexNet Licensing error:-15,10. System Error: 10061 "WinSock: Connection refused"
This article will provide some troubleshooting steps for the -15:10 error.
After updating your Floating License server, when pressing the start button, the information will load but the 'start' button will remain. You may also receive the error code:
Looking through the LMTools software to see what caused the issue, you may find that you are unable to start or stop the license server and receive the error message:
Unable to Stop Server. Check the License search path and VD status.
This error may occur due to an incorrected configured service or ports, or an incorrectly modified license file or a permission issue or an older version of the software.
Update the Licence Server Sorftware
As a first step, it's best to update to the latest License Server Software:
https://download.keyshot.com/tools/luxion_license_server_setup_x86_v1.16.exe
https://download.keyshot.com/tools/luxion_license_server_setup_mac_v1.16.pkg
https://download.keyshot.com/tools/luxion_license_server_setup_linux_v1.14.zip
LMTools might not reading the correct license file.
In LMTools under the 'Start/Stop/Reread' tab, at the bottom of the window you will see the file path to where the license is located.
Make sure the file path leads to the correct location. There can be multiple licenses in this area, so please be sure the correct license is being used.
You can check and make any changes by selecting the 'Config Services' tab and clicking the 'Browse' button.
Enter the correct file path and select the desired license file.
Save any changes made and close LMTools.
Reboot the server host and reopen LMTools tools to confirm the changes have been saved.
You can restart the Luxion License Server through LMTools to bring everything back online.
Forwarding Ports
Please make sure that the ports are open
  • FlexLM Port: the default port is 27000
    • If you have another License server running on the same machine or cannot forward the default port, you may change it through the Licensing Server Software
  • Daemon Port: by default uses a random port in the range range 49152 - 65535
    • You may fix it to a specific port in the Licensing Server Software
How to change the Port Numbers:
  1. Start the Luxion License Server application.
  2. Go to the Install License tab.
  3. Click Set Server Ports.
  4. FlexLM Port: Change this to avoid port conflicts.
  5. Daemon Port: This is only used for network setups with a Firewall.
    1. If a Firewall is used, both ports need to be set and opened in the Firewall.
  6. Click OK.
  7. Click Reread License File to make sure the changes are applied.
The License server is configured as a Local Service account, rather than a Local System account.
To resolve this, please follow the steps below
  1. Open Administrative Tools:
    • Click on the Start menu.
    • Type “Administrative Tools” and select it from the search results.
  2. Access Services:
    • In the Administrative Tools window, double-click on “Services”.
  3. Find Your Service:
    • Scroll through the list to find the service related to your license server (e.g., “FlexNet Licensing Service”).
  4. Open Service Properties:
    • Right-click on the service and select “Properties”.
  5. Change Log On Account:
    • Go to the “Log On” tab.
    • Select “Local System account”.
    • Click “Apply”.
  6. Restart the Service:
    • Go back to the “General” tab.
    • Click “Start” to restart the service.
    • Click “OK” to close the properties window.
License file is being read incorrectly
Lastly, you could try a fresh floating install.
How to do a Fresh Install of KeyShot floating license.
  1. Open Luxion License Server software.
  2. Click on the Install License tab.
  3. Click on the License Folder button.
  4. Click on Stop Service if it's running.
    1. Once the Service has stopped close your Luxion License serve software.
  5. Go to the License folder and delete all files in the folder.
    1. You can move them to another folder if you would like to keep them backed up.
  6. Launch Luxion License Server software.
  7. Click on the Install License tab
    1. (The license field should be empty)
  8. Download your license file from your email, or from a saved location.
  9. Click the New License button.
    1. Navigate to your KeyShot floating license file.
  10. Service be created and the license should start up.
If the issue is not resolved, please create a ticket through our support portal
Please provide your license file and the Floating Logs
The LUXION.log and debug.log (which is not always created) are located in the FlexLM License folder
  • C:\FlexLM\
  • C:\ProgramData\Luxion\License
  • MacintoshHD\Applications\LuxionLicenseServer\Contents\License
