High CPU Usage on macOS When Running KeyShot
Understanding Why KeyShot May Show CPU Usage Over 100% on Mac
Issue
While using KeyShot for Mac you may notice your CPU usage spikes to over 100%. This behavior raises concerns about system performance and whether it's abnormal or potentially harmful.
Environment
  • KeyShot Studio (Any version)
  • macOS (Apple Silicon)
Cause
On macOS, CPU usage in Activity Monitor is calculated per CPU core. That means:
  • 100% = one core fully utilized
  • A system with 8 cores can show up to 800% total
So KeyShot showing 202% simply means it is using just over two CPU cores. This is completely normal, especially during:
  • Real-time rendering
  • Working with complex scenes
  • Background calculations like lighting or material previews
Resolution
No action is needed — this is expected behavior.
If you want to reduce CPU usage:
  • Enable Performance Mode in KeyShot to reduce resource load while modeling.
  • Simplify your scene (fewer materials, lower geometry detail, or turn off real-time shadows).
  • Pause real-time rendering when not actively needed.
KeyShot is designed to utilize multiple CPU cores efficiently, so higher usage during intensive tasks is both normal and beneficial for performance.
