How to change the KeyShot Floating License Port Number
Changing KeyShot Floating License Port Number
Follow these steps to change the port number for the Floating License Server.
Prerequisites
  • KeyShot
  • License Server Application
  • Windows Admin/Network Admin privileges
Procedure
How to change Port Number with Luxion License Server.
  1. Start the Luxion License Server application.
  2. Go to the Install License tab.
  3. Click Set Server Ports
    1. FlexLM Port: Change this to avoid port conflicts if you have other license servers on the same machine. (Default: 27000)
    2. Daemon Port: This is only used for network setups with a Firewall. If a Firewall is used, both ports need to be set and opened in the Firewall.
  4. Click OK.
  5. Click Reread License File to make sure the changes are applied.
How to change the ports manually
  1. Open your KeyShot floating license with a text editor.
  2. Look for the Server line.
  3. After the MAC address add your port number. (Default port 27000)
  4. You can also add a port to Vendor Daemon by putting PORT= ####
  5. After adding ports save your changes.
  6. Open Luxion License Server.
  7. Go to Install License Tab.
  8. Load KeyShot floating license.
