KeyShot Fails To Launch on Windows 11
Issue
KeyShot fails to launch when you click on the icon or try to open it. This article addresses a specific issue that occurs when on Windows 11.
Environment Details
  • KeyShot
    • 11, 2023, 2024.1, 2024.3
  • Windows 11
Cause
  • Issue with the Intel Graphics Driver
  • The High Performance GPU has not been selected so rather than using the NVIDIA GPU, KeyShot is trying to use the Intel Graphics card
Resolution
Note: The below resolution will only work if you have another GPU rather than the Intel Graphics card included with your computer.
Set the GPU to "High Performance" by following the instructions below:
Set preferred GPU setting on Windows:
  1. Press the Windows + I shortcut to open the Settings app and click on Display.
  2. Under display settings, scroll down and click Graphics.
  3. Click on the Browse button and select the following depending on how KeyShot was installed
    Installed just for Me:
    %localappdata%\KeyShot##\bin\keyshot.exe
    Installed for everyone using this computer:
    C:\Program Files\KeyShot##\bin\keyshot.exe
  4. Click on the Options button and select "High Performance" from the Graphics specifications drop-down menu.
  5. Click on the Save button to apply the changes.
  6. Restart KeyShot
If you find that this does not resolve your issue, you may need to downgrade or upgrade to a version that does not have this issue. Both KeyShot 10 and KeyShot 2024.2 do not appear to have this issue.
If this does not resolve the issue, please contact our support team by submitting a ticket in our support portal.
