KeyShot floating license won't start
When trying to load your KeyShot floating license and it fails to start up, you can look at the Luxion log file for more information.
- Start Luxion License Server (if not already opened)
- Go to the Install License tab
- Click License Folder
- Your License folder will open.
- Open the Luxion log file located in that folder.
When you open the Luxion Log file and if you happen to see any messages like the one below.
License Manager: can't initialize: Cannot find license file.
The license files (or license server system network addresses) attempted are listed below. Use LM_LICENSE_FILE to use a different license file, or contact your software provider for a license file.
- Filename: "C:\flexlm\license.dat"
- License Path: "C:\flexlm\license.dat"
- FlexNet Licensing error: -1,359
- System Error:2 No such file or directory
- Using license file "C:\flexlm\license.dat"
Can you follow the steps below to resolve the licensing issue?
- Open LMTOOLs and select the Luxion License Server from the list.
- Go to Config Services.
- Click on Remove Services to remove the KeyShot License.
- Open Luxion License Server.
- Click on the Install License tab.
- Click on New License.
- Select your KeyShot Floating License file.
If you are still having issues after this send us the Luxion log file by submitting a ticket to in our Support Portal.
