Plugin Live-Linking
In this article, you will learn how to establish a connection between your 3D modeling software and KeyShot.
Issue
Luxion's LiveLinking technology allows you to establish a link between your 3D modeling software and KeyShot. This keeps the software separate, allowing you to continue working and refining your model in the CAD application, then send all changes over to KeyShot with the click of a button. All without losing any views, materials, textures or animations already applied.
Environment Details
  • KeyShot
    • Any version
Resolution
Download Plugin
To establish LiveLinking between your CAD application and KeyShot, you must first download and install the KeyShot plugin for your CAD application.  Each plugin comes with its own installer and unique setup instructions. For specific setup instructions, click here.
Enable LiveLinking
LiveLinking is enabled by default. To change this go to Edit, Preferences, General on Windows and Keyshot, Preferences, General on Mac.
Unable to connect
If the your 3D modeling software is unable to connect to KeyShot via the plugin, try to change the Port Range in the KeyShot Preferences
